Everything Works But Wash. It Wont Pump Water Into Spray Arms It Humms Or Stays Quiet For A Bit Then Drains And Says Clean. Nothin Was Clean
Hello,
If the motor itself is still good (check it for continuity) then you can fix it by installing the new impeller & seal kit. It comes with the installation instructions. You have to remove the pump & motor assembly from the dishwasher to do it. You can find the instructions in one of our previous threads: http://forum.appliancepartspros.com/dishwasher-repair/176535-hums-but-wont-cycle-no-water-flow.html#post368518
If the motor is bad then you have to replace the whole pump & motor assembly.
The impeller & seal kit WD19X10038
The pump & motor assembly WD26X10045
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-ge-ghda486n10ss.html
i drained then killed power then off water pulled out flipped on its side pulled motor offf checked propeller and sump and where ever the water must travel. everthing was clean and clear movin freely. bad wire connect all good works great.
I’m glad to hear you were able to find and fix the problem. Good job!
