fixed motor coupler…now washer won’t stop filling and won’t agitate :eek:
Sounds like the pressure switch hose came off.
That is a clear rubber hose running from the bottom right side of the tub up to the level switch.
Check that hose. You should be good.
Matt
Thank you all!!! The problems were all solved, and we’re back to doing laundry again. Amazing experience having others help us without costing a dime. brokenshoe family
— Begin quote from t7433;16816
I have the same problem. If the hose came off would the tub leak? Mine after filling up leaks from the left front of the bottom outer tub. Or would it be the tub seal?
Sounds like your tub seal.
Matt
