wont turn on
This dryer was running fine, wife went to use it and nothing, I thought it might be the relay, if so ,I would fix myself, seems easy enough, can someone with appliance repair experience offer any insight on what the problem may be. I checked all the circuit breakers already. Thanks, Joe
Joseph, if you are getting power to the dryer, try checking the door switch. You can test it with a ohm meter just pull a wire off one side of it. If it still won’t start there is a safety fuse that you can check that should be white and have two wires going to it. Pull one of the wires off it and put your ohm meter on it. If no reading replace fuse. As for the door switch, pull a wire off one side and actuate the button. When it is pressed as if the door is closed and you don’t get a reading then replace that switch.
