has a F2 code come up what does this mean?
Listen this code is clear as mud. If you like your oven and are prepared to put in both oven sensor, and the clock control board(ERC). Here is what you do. Buy the sensor first. If that does not work, buy the ERC. You could ohm out the sensor, and see if it ohms out between 1070 ohms, and 1100. Tom http://www.applianceeducator.com/parts.htm
