works on and off
it started out overflowing. replaced water pressure valve. worked 1/2 days stopped filling with water. would not agitate but the whole time it has continued to spin. poured 3 gal of water in tub it started filling with water but overflowed. put in spin mode it drained out perfect. did that 3 times with same results. today the onlt thing it will do is fill after pouring in water. will not spin now. water can come in water can go out. it can aggitate and spin. just don’t know when it’s gonna do what.
Your symptoms suggest a problem with the timer, so I would change it out.
If you need more info please post a model number and tell us what happened with the timer.
Good luck.
