My washer has started to leak from the underneath bottom front. It seems it leaks or leaks more when it goes into the rinse cycle. any suggestion on what this might be and is it a costly repair…thank you
It’s probably the pump leaking. It’s going to be one of the following.
AP2907492
AP2908525
