when you shut the freezer door the auger comes on until you reopen door. it will stop if you lock it out on display on door. the diagram is missing. have changed door switch and power board with no change. i have now noticed a pin point puncture in the ribbon. the hole is between the strips cant see if touching metal. do you think power is jumping across through hole or maybe in display board? thanks so much
Related topics
Frigidaire DGHF2360PF2A Ice Auger Runs Continuously | 2 | 140 | November 20, 2023 | |
fridgedair sidebyside icemaker runs when you shut freezer door | 2 | 734 | January 14, 2014 | |
Fridgidaire Ice Maker Auger Motor Won't Stop Running | 2 | 1183 | November 20, 2023 | |
chwn2001 | 1 | 1052 | May 23, 2012 | |
ice auger stopped working in GE side-by-side | 2 | 5240 | October 24, 2007 |
