One of the baffles inside the dryer is loose. It appears to be secured from the outside of the drum. How do I access the baffle in order to tighten the loose baffle. Thanks, Ron
Two spring clips are located at the top of the front panel. You can usually see them, about an inch and a half in from each side. Push in on them with a putty knife or a similar item, while also lifting on the top, and they’ll pop loose, allowing you to lift the top up. The baffles are held in place by three hex head screws.
