I must set the temp on my Jenn-Air SVE47600B oven 40 to 50 degrees higher than the temp I really want. For example, if I want a 350 degree oven I must set the temp to 390 to 400 degrees. If I want a 400 degree oven I must set the temp to 440 to 450 degrees. Any suggestions? Thank you in advance.
Related topics
Oven not heating too set temp | 0 | 1198 | January 5, 2008 | |
Jenn air oven heats, but not to correct temp | 1 | 1219 | July 14, 2008 | |
Oven Temp does not match setting on thermostat | 1 | 1635 | September 30, 2009 | |
Does not heat to requested temp. | 1 | 872 | November 15, 2011 | |
Wrong Temperature- | 1 | 991 | September 25, 2009 |
