The oven does not heat to the set temperature. At 350 it is 325 and at 400 it is 370. I have verified this with 2 different oven thermometers. Is the thermostat bad? If so how do i replace it? Thanks for your help.
Related topics
Actual Oven Temp Lower Than Set Temp | 1 | 1263 | January 6, 2012 | |
Jenn air oven heats, but not to correct temp | 1 | 1216 | July 14, 2008 | |
Oven Temp does not match setting on thermostat | 1 | 1634 | September 30, 2009 | |
Jenn-Air Oven not reach set temperature | 1 | 1910 | April 3, 2013 | |
Jenn-Air Wall Oven not heating properly | 1 | 3459 | March 8, 2010 |
