adgitater dogs
Trying to relace dogs please help
[LIST]
*][SIZE=3]Pull the cap or the fabric softer dispenser of the top of the agitator.[/SIZE]
*][SIZE=3]Under that cap you should see another cap, remove it. [/SIZE]
*][SIZE=3]Remove the 7/16 bolt down in the agitator that holds the agitator on.[/SIZE]
*][SIZE=3]Pull the agitator up and out of the washer. [/SIZE]
*][SIZE=3]Down in the agitator you should see two tabs that are bent over straighten them out. Then separate the top of the agitator from the bottom by simply pulling them apart. [/SIZE]
*][SIZE=3]Once apart you should see the agitator dogs in a holder remove them and install the new ones. [/SIZE][/LIST][SIZE=3]When putting the agitator back together you must line up the two tabs while holding down on the holder so that they won’t fall back out. Once the tabs are lined up you should be able to push the agitator back together. Hope this helps![/SIZE]
[SIZE=3][/SIZE]
http://www.appliance-repair-it.com/clothes-washer-repair.html
