Admiral dryer makes sqaking noise
I have an admiral brand dryer, model number ADE7005AYW. Have only had this dryer maybe two and half years. It started squeaking off and on a couple months ago, but now it squeaks continually when it is running. It heats and dries the clothes fine. Can you tell me what may be the problem with it, the parts to buy and their numbers and how to go about opening it to fix it? Thanks.
Remove the front panel and the front bulkhead. Check the front glides (#3 on the diagram). Both glides have to be replaced at the same time.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176934
