Hey guys,
My admiral dryer has been squealing really loud and tonight I decided to disassemble the dryer… when I got it apart I saw metal shards everywhere and after looking around found the right glider barely hanging on. The bracket seems to have been rubbing on the drum as well as the metal motor mount. After inspecting further I found the drum is hanging down to the right. I cannot figure out why, I’m new to this so I’m looking for expert help. What could be causing the drum to hang and what will need to be fix/replaced?
A model number may help others help you.
This does sound like you will be the only one that can determine the cause since you can see what exactly is worn.
All I can suggest is that you check the the rear and front drum supports.
Also check the drum seals.
denman said:
A model number may help others help you.This does sound like you will be the only one that can determine the cause since you can see what exactly is worn.
Sorry didn’t have model number handy when posted, the model number is ADE7005AYW. I took it apart again and took the rollers out and looked at them, they seem to be fine, but then again what do I know? Lol I cannot figure out what could be causing the drum to rub…
http://www.appliancepartspros.com/parts-for-admiral-ade7005ayw.html
Have you replaced the front glides?
Also if the bracket is badly worn replace it.
