Admiral dryer squeaks and makes noise
my dryer works as far as drying and tumbling but it squeaks and when you first start it it sounds like it has a hard time getting started… any suggestions:confused:
Mike, You’re going to need to check the idler pulley, drum glides and the drum rollers and of course the belt. You’ll need to remove power to the dryer, raise the top, and remove the front panel, to access the interior. A model number would have been a great help. We could have been a bit more efficient, but that’s a basic break down for a basic Admiral dryer.
Thanks and Good Luck,
