Affinity door switch replacement
I am ready to replace the door switch and the wiring harness. I need instructions on how to do this. Do I go in from the top or back.
Hello,
Most likely you have to do it from the front. The instructions are attached to the post. Look at the door lock picture bellow. If the old part looks exactly the same then you don’t need a new wiring harness.
Here are the breakdown diagrams and http://www.appliancepartspros.com/parts-for-frigidaire-atf6000es1.html
Ok, thanks for the info on the door switch removal. When I ordered the new part, appliancepartspros said I had to have a new wiring harness and when it arrived, it had a lot more wires and hook ups than are shown in your diagram. To replace the whole harness, do I need to go in from the top or can I do it from the front?
What is the part number of the wiring harness you ordered?
In order to replace you have to remove the top panel too.
