My Friend has a old Kenmore washer 80 Series Ultra Fabric Care and it only agitates but won’t spin out the water.What could the problem be.I believe this unit has no belt and I need some help in order to help her fix it.
The pump mounts on the motor. The motor pumps out the water. It won’t pump or spin if the lid is open. Check the lid switch. Here is a picture of a broken lid switch[ATTACH]236[/ATTACH]
Unplug the lid switch quick plug as pictured[ATTACH]237[/ATTACH]
Check the 2 outer connectors for continuity. With the lid shut the switch should have continuity. If it is open it is bad. To access the switch simply pop those brass S-clips and tip the outer case forward.
