Agitator for Frigidaire Laundry Center
Help! I am trying to find a replacement agitator for this unit. They tell me that it is no longer made, and the one the factory suggested to replace it is also not available anymore. Any suggestions on where I could get one that would work. It seems bad to just throw this unit away because of that.
All help appreciated!
The only way is if you can find the same old washer (the same model) and take the agitator from it.
Thanks. I was hoping that Frigidaire may have made other models that would interchange. Did Frigidaire make any other brand names? I saw a speed queen agitator that looks a lot like the one for my washer.
If any parts are interchangeable than it must be a reference next to the part number. If it says on a part list "has been discontinued" or "no longer available", it means what it says.
Is there a cement or glue required to replace this gasket? If so is it included in the ‘seal kit’ or nust it be purchased separately?
