[SIZE=4]My agitator on my GE washer spin when started then gradually slow down and stops even I made sure the load is balanced. This problem is worse when it’s in the spin cycle. It also make lots of noise (sounds like bad bearing) when spinning.[/SIZE]
[SIZE=4]If I need to remove the agitator, I need help in how to do it.[/SIZE]
[SIZE=4]This model is a heavy duty with 8 cycles and two speed and I believe it’s no older than 5 years.[/SIZE]
[SIZE=4]Thank you for your assistance.[/SIZE]
