I’m trying to replace the broiler ignitor on a wall unit (over under) in the top oven. I’ve started taking the broiler shroud off and realized the wiring goes into the side of the oven…what needs to be taken off to access the side of the oven to the wiring?
Just cut the wires at the old ignitor, and wire the new one in!!! Wire nuts normally come with a new ignitor. Tom http://www.applianceeducator.com
I thought about that, but I figured there’s another set of wire nuts already inside the oven somewhere and I didn’t want to have two sets wired in. Besides, I found that wasn’t the problem. Now the problem is the oven won’t light. Broiler is working fine now though. Thanks for the reply.
