Replacing broil ignitor on Amana built in oven
I had no problem replacing one of the bake ignitors on this built in range, since in only required removing one of the front plates. I need to replace both broil ignitors as well, and I don’t see how to do it. Disconnecting one of the ignitors and pulling gently still leaves the connecting wires and wire nuts somewhere inside the side wall of the oven, and there is no obvious means of access. How do I get access to the connections so the replacement can be done?
Steve
— Begin quote from StephenDashiell;264373
Steve
Steve,
Here are the instructions for both the bake and broil igniter(s) and burner(s) from the service manual for your Amana wall oven.
Good Luck,
[FONT=Arial][LEFT]Broil Ignitor[/LEFT]
[/FONT][FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]1. Shut off power and gas supply to oven.
2. Remove oven doors and oven racks.
3. Unscrew broil ignitor wire cover mounting screw.
Remove cover.
4. Remove broil ignitor mounting screws. Pull ignitor
leads and connectors into oven cavity through hole in
broil chamber.
5. Disconnect ignitor wiring.
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][LEFT]Broil Burner[/LEFT]
3. Remove broil ignitor mounting screws. Remove
ignitor from broiler burner.
4. Remove broil burner mounting screw securing burner
to burner bracket.
5. Move burner up against burner bracket. Push burner
towards rear of oven. Slide broiler burner out of broil
chamber.
[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][FONT=Arial][LEFT]Oven Burner Ignitor[/LEFT]
3. Remove oven bottom by pushing it slightly towards
rear, lighting from front and sliding it out of oven.
4. Remove screws securing ignitor bracket to back
burner box. Remove screw securing ignitor to bake
burner.[/LEFT]
[FONT=Arial][SIZE=2][FONT=Arial][SIZE=2][LEFT]5. Pull ignitor leads and connectors through opening.[/LEFT]
[FONT=Arial][LEFT]Oven Burner[/LEFT]
2. Disconnect gas supply to oven.
3. Remove oven doors and oven racks.
4. Remove oven from enclosure.
5. Remove oven cabinet top.
6. The self-clean relay is mounted to the right control
compartment side panel. Remove upper and lower
relay mounting screws.
7. Disconnect relay wiring one at a time. Reconnect[/LEFT]
wiring to appropriate terminal on replacement relay.
[/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT]
