Amana dryer not drying...timer not counting down
Hello-
A couple of days ago I posted that our Amana dryer was turning on by itself after closing the door even though we had not hit the power button on. Today, I tried to dry a small load of clothes and we are having more problems. Now, the clothes aren’t drying and the timer is not counting down. Please help!!
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=NED7200TW
Try running the diagnostics to see if you can get more info on the problem.
Check/clean your moisture sensor.
Check that the heater is coming on.
So we ran the service check and got codes 4 and 10. If it is the control panel, how hard is it to replace it? Is it something we can do ourselves or should we have someone come out and do it?
Here is the manual that comes up when I use a comparable Maytag unit. It should be close to yours and should help you decide.
http://appliancedigest.com/index.php?/files/file/473-16025911-maytag-27-inch-dryer-service-manual/
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Timer doesn’t turn frigidaire dryer
James Vandergriff
Answering here will just confuse things re: a different maker and problem.
Also I usually do not deal with gas dryers.
