Amana Dryer squeeks/grinds
Amana dryer, when running squeeks and then grinds. I think the grinding is from the belt slipping because the rollers are bad. I just wanted to get ur opinions to see if I’m on the right track and also, what parts will I need to complete the job?
Besides the rollers you may want to check the front glides (#11 on the [B]Service manual.
  • The dryer drum glide (has to be ordered two) AP4046795
  • The roller (has to be ordered two) AP4046756
Here is the [URL="http://servicematters.com/maytag_library/docs/RS3200007R0.pdf).
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=22271
