Amana Ice Maker Makes Ice Does Not Dispense Ice
Replaced my water valve, the ice maker no longer leaks, makes ice. But now, the ice dispenser does not work. Doesn’t seem to be getting any power. The Auger does not turn, no motor noise. The water dispenser works fine. Please advise. Thanks in advance for your responses.
Me again! Behind the water valve I replaced there appears to be another valve located behind the water valve. Could this model have 2 water valves? Does the other valve need replacing too? BTW, the icemaker is overflowing again. Thanks in advance for your responses.
Question on the plugs: One is brown, the other clear. Does it matter which terminal the plug is plugged into?
