Amana LED20AW No Heat
Motor runs tub rotates. The dryer is not heating. Heating Element is measuring 10 Ohms and but is only getting 58V AC. checked the feed coming from the top of the dryer to the 1st temp switch on the vent and there is only 58V coming down from above. Need a service manual/wire schematic to go further
Check your timer. Find the wire going from timer to heating element. Remove the wire. Clamp your ohm meter at that point and measure ohms resistance on all other terminals of the timer at all positions on the dial. If cannot get an ohms reading then your timer contacts are fried. [ATTACH]2116[/ATTACH]
Amana dryer service manual
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LED20AW
Here is a manual
http://www.servicematters.com/maytag_library/docs/RS3200005R2.pdf
You did not say but have you checked the power going into the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
I found over the weekend that the Cord was burned out at the terminal attachment to the dryer. L2 totally was gone
Glad ye could get er done!:smiley:
