Yesterday my dryer was working fine. Later in the evening it just stoped working. I go to turn it on and I get a couple clicks but the motor wont spin. It spins freely by hand. I pulled the back off and found a little lint. I blew all of it out with my air compresser and shop vac.
I’m getting 240V to the plug and 120 across each pole.
What I need to know is what to be checking? and a wiring diagram for it.
The control lock on the panel doesn’t turn red, But when you open the door the DO code comes on. So i’m guessing the door switch works. The other 2 codes do not show up.
