With the wires swapped on the valve, the water dispenser will send water to the ice maker? If yes then replace the valve. If not, no.
the answer is no. I can’t get water to send to the ice maker regardless.
as soon as i hook it up to the back of the freezer is stops pushing water to up the tube. as soon as i disconnect it, at the top, it pushes water up the top.?
thoughts?
So you are getting water into the ice maker if you switch the lines? If so, it’s not a frozen line. On my Amana side by side the water line that goes into the ice maker (large rubber line that goes from the back wall of the freezer down to the ice maker) has frozen up a few times, but it’s easy to check…just squeeze the line and you can tell if it’s frozen solid or not.
Wow…I guess i’m just out of luck?
No one has any advice?
The water inlet valve is leaking. Replacing it will stop the fill tube from filling with water and freezing.
it is making full tubs of ice now since i thawed out the supply tube…
if it keep freezing…does that mean that i need to get a new valve? just checking ahead of time…
thanks
Hard to say, You may need to swap the ends (electrical) to the water and Ice maker to ensure that it is not a valve problem, and then replace the icemaker if it is not.
