Amana side by side
My frige/freezer quit cooling so I took off the back panel in freezer and noticed ice build up on coils but evap motor fan is not running. I unplugged the unit and cleaned off all the dust around condesor and all under back of fridge. I also replaced the evap fan motor but to no avail. Any tips on what to check now? Fan in back of fridge is running and compressor is warm. Thanks in advance
Ok, found defrost timer under front of refrigerator. Advanced until it clicked and the fan in back went off. Now what would be the next step? Do I have to wait awhile before doing anything else? Thanks in advance.
Problem solved. It was the defrost thermostat as it was expanded/exploded. Replaced and everything is working just fine thus far. Thank you for your response and the info liberty.
