Annoying Drip (Kitchen Aid)
Model: KSCS25FTMS02
i USE REVERSE OSMOSIS SO NEVER HAVE USED A FILTER. IN THE LAST COUPLE OF MONTHS THE WATER DISPENSER DRIPS. NOW IT DRIPS MORE SO WE PUT A GLASS UNDER IT INSTEAD OF EMPTYING THE TRAY SO OFTEN HELP!!!:o
Semper Fi
Sounds like you need a new valve.
AP3886069
Click on the picture for more info on it and a Q&A.
If you have a shut off valve in the water line to the valve check that it is wide open.
Many valves actually use the water pressure to help with sealing the valve.
