Another KitchenAid Superba stops working after cleaning cycle
This one stopped just a few minutes shy of the end of the 3 1/2 hour cycle, so the door is locked shut. This happened before, years ago and some part was replaced and the oven worked. Another thread with a similar but not exactly the same model showed a need to test with some sensor ? to determine if a thermal fuse needs replacing. I didn’t know if this likely applied to mine and if so, how do I track down the part? Plus, how do I get the door to open?
I also have the plastic/rubbery cover for the controls that is partially detached when cool I believe this was a result of the oven heat fromt the cleaning cycle. It looks like it should be able to be "glued" back but I don’t know what to use?
Last, when cleaning the oven the old fashioned way-with a spray, some of the spray ran in through the oven door and onto the glass and I would like to get that cleaned. If this oven is worth saving is there an easy way to get to the glass to clean it?
That’s all I have :):slight_smile:
Thanks for any and all help
I believe the grey wire goes to the MDL1 terminal and the black/white wire goes to the MDL2. The black wire usually is the hot line. There is suppose to be a tech sheets with the wiring diagram inside the control panel compartment.
