Cleaning cycle killed our KitchenAid Superba double oven, help?
Hi:
We ran the cleaning cycle on the upper oven of our KitchenAid Superba double oven. About halfway through the cycle, the oven shut off completely. There are no lights on the control panel and the upper over door is locked.
I flipped the circuit breaker that’s going to the oven a few times, but it is still totally dead.
Does anyone have any ideas?
Thanks,
PL
Gene,
Thanks a bunch! Finally got the upper oven door open and the Mod # is KEBS277DBL4. Working on removal of upper panel to see why it just dropped power dure clean cycle. Breaker is OK.
Jim
How do you pull cap off the fuse so you can change it. Our Kitchen Aid model is KEB1271BWH1
Checked the glass fuse for the panel and it is OK. Found thermal fuse on connector P4: Pulled off wire connector and had to use an Ice Pick to remove it from the connector block by pushing in the connector end.
Fuse is bad and waiting shipment of new fuse.
Jneyens
— Begin quote from jneyens;152328
Jneyens
Very likely the upper oven thermal fuse (#37 on the [B]diagram[/B]) is bad as well. If the oven would not heat after you replace the control panel thermal fuse, pull the oven out of the cabinet and replace that fuse too.
In order to avoid having such problem again do not use self clean.
— Begin quote from JABDDB;151731
What is the original problem with your oven?
Gene, thanks for your help.
Same here, KitchenAid KEBC207KWHO, made by Whirlpool; after lots of work, problem, encountered by many, is probably the thermal fuse behind the control panel, Part AP3777386 (under $20 with regular shipping). Pain to pull out oven but doable. Another frequent failer is the second thermal fuse or disc at the back of the top oven (need to remove the top back shield); this just kills one or both burners not the entire unit, I understand (had this problem 18 months ago); Part No. AP 3879224 replacing 4452223, $35 w/o shipping; Noticed one of the suppressor terminals was blackened so ordered it too out of caution; back of top of oven, Part No. 3192767. Only part number not observable on the actual part was the thermal fuse behind control panel; it is encased in clear plastic, no part number printed on it.
Many suggest not using the self cleaning feature. Helluva lot easier to manually clean than to pull the oven out and agonize.
Because I saved the manual, I know that I’ve one of the following models: KEBI276D/101D/141D/171D & having the same problem described in these posts. Oven died during self-cleaning & breakers are okay.
I pulled out the Control Panel, but I cannot unlock the top door since there is another plastic panel between the control panel & the top oven. I removed 2 screws on it, but there are 2 more screws that are not reachable while the top door is closed! So I cannot tell you what my model number is exactly. HELP!
I can see the P4 fuse behind the control panel. How do I tell whether it’s gone bad or not?
Many Thanks in advance to ALL, esp Gene.
If the oven is completely dead, then the fuse behind the control panel is almost certainly the culprit; it was in my case but by inspecting it I could not determine that is was blown.
I had to pull the oven out and fiddle with the upper door latch to get the door to open, allowing me to see the model number label.
Out of caution I replaced the second, disc fuse on the back of the oven, as well as a part called a suppressor that had blackend (burnt) connections.
I also had to replace the upper door latch; had a tough time as the location of the two sets of side connections are switched. Would ask for the wiring harness and a diagram if I ever had to replace it again; hopefully it might come pre-wired, only needing to be plugged into the control panel.
I have a Kitchaid Superba Mod: KEBC147KSS05 SER: XS4209882
This is the second time my oven has stopped working after self-cleaning feature used. The first time, the repairman blamed it on my not using the self-cleaning feature enough. The first time, it was an expensive repair, just over a year ago.
This time, I did a search and discovered this is a wide-spread problem.
I just spoke to the repairman. He states the blower and thermostat need replacing and that parts alone will be $340.15. After reading on this site, it looks like it is a fuse that causes the problem???
I won’t use the self-cleaning feature again but don’t want to have him repair the wrong thing. My husband is pretty handy so I may see if he wants to do this repair…
— Begin quote from JoyKimbrell;316221
If the control panel is completely dead, the thermal fuse is probably blown. Certainly would be the first thing to try as it is $11 or so plus shipping, and your husband can surely replace it.
— Begin quote from teocjr;316308
Control panel is not completely dead…it says "Lo" and I hear a fan but it does not warm up.
teocjr said:
Then I would change the thermal fuse or disc on the very back of the oven. $35 plus shipping, and of course a lot of work to get the oven all the way out so you can make the change. Kill the power of course while doing the change. If that doesn’t do it, then you may have to call a "technician". Good luck.
Just to add my 2 cents…
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5137782
Thank you for your help! I appreciate it. Part ordered and my husband is going to give it a try.
Interestingly, he talked to a rep at Whirlpool and then the corporate office and they deny knowing anything about a problem with the cleaning cycle killing KitchenAid ovens…unbelievable! I’m going to write them a letter and direct them to this forum and the one on facebook.
Wow…parts (thermal fuse & blower) came in (we had them sent two day delivery) and my husband replaced the parts with no problem. Oven is working again. What a service you talented people (Gene & teocjr) are providing on here!! You saved us a ton of money!!! Thank you, thank you, thank you!!
You are welcome Joy. We are glad you were able to fix it.
Thank you for your good words.
Happy Holidays!
— Begin quote from Gene;318014
Happy Holidays!
Again, many thanks to Gene and teocjr for info on this problem. I posted a YouTube video YouTube - KitchenAid Superba Wall Oven DIY Repair that may be helpful to DIY folks.
Joy…let me know what happens with your corporate letter! It is clear that this is a widespread problem.
I have followed this thread and have removed control panel, got top oven open, found model number : KEBS278DSS6
I am in the middle of this repair now and would like to know how I can tell if my thermal fuse is blown? Forgive my ignorance. Should I just order the part and see if it works with a new one? Thank you for all of your posts and help! It is much appreciated.
~Carrie
Carrie,
If the display is blank then you have to replace both thermal fuses. One for the control panel. You can identify it by the following picture. The second thermal fuse is for the oven heating circuit. It is located on the back of the oven. So the oven has to be removed from the cabinet to access it.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=259777
