As if it is not plugged in
I have a Maytag model LA310. It has always worked well until about two days ago. Now it does absolutely nothing. The electrical outlet is fine and the water is on. After a search in this forum I think that it might be the timer. Apparently the timer has been discontinued by Maytag.
I would prefer to keep it as the the dryer is fine and the washer had always been a workhorse.
Any suggestions? And thanks in advance.
It is the lid switch. Fixed with a wedge. I’ll order one and install.
Glad you found the problem.
Thanks for the update.
