Hi folks,
We recently acquired an Asko washer and dryer. The dryer is a model 7305. It was apparently working at its old home.
Upon getting it home and hooking it up, it runs for a couple of minutes, and then shuts off with an F5 code, indicating a problem with the humidity sensor. Internet research tells me that it could be as simple as lint on the sensor, could be wiring, or could be a bad sensor.
Where would I expect to find this sensor? Once I locate it, is cleaning it about the only thing I can do short of replacing it?
