Press any of the wash cycles and the washer draws water in and the heater coil warms up but nothing happens with the pump/motor. There is a medium low humming noise. If you stop and drain the water will pump out into the sink drain.
Any ideas ? Is this a stuck or burnt motor ? Any sensors that could be stopping the motor from starting ?
