washer will fill, drain, do all things but wash, took accumulator off of sump and got down to chopper and was able to turn in one direction easily but would stop in the oppisite direction, ran diag. and all worked except wash again. is this the motor bad or could it be a sensor. did not see any debree in the impeller area, please help.
[https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10130990.pdf](http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=gu2455xtsb3"]Replacement parts for WHIRLPOOL GU2455XTSB3 | AppliancePartsPros.com[/URL]
Here is a tech sheet
[URL="https://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%20W10130990.pdf)
If the unit is not stainless it could be a door switch, it kills the motor and the heater, see the wiring diagram upper left hand corner.
Check it with a meter to see if it is getting voltage when it should.
heater is working and just pulled unit out and the motor is warm to the touch. will check capcitor and motor resistence next any other suggestiongs would be welcomed. thank you
Perhaps the motor is running just the impeller is not turning.
Here is a service manual, it is for a different model but the pumps look the same. Hopefully it it be helpful.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
Thanks for all the help it was the motor. front bearing failed due to leake, took to a electric shop up the street and replaced bearing in motor for 7 dollars. thanks for the help!
My brand new Bosch is spraying soapy water out at the vent which is on the top deck of the counter.
I got a used frig.,it sat for over a year,It worked fine for 2 months but when i hooked up the water the dispencer works fine but the Ice maker would only make a few cubes then stop,It started to make noise and turned off altogether then restated.I pulled the water tube out it only drips water is this enough or should it flow freely.It appears to be freezing the motor.
