Bad Vibration from Whirlpool Dryer
My dryer seems to be working OK other than a horrible vibration and noise that just started. Can I continue to use it or will it cause more damage? Is it something I can fix?
— Begin quote from kecowart;216515
It can cause more damage. You need to have someone to check the rollers that turn the tub the bearings might be damage or it could be that the drum is not positioned right/
