bake and broil dont work
the bake element blew up. i replaced the element and while i was at it, replaced the display board which had gone dim. the display and clock work good as does everything else(stove top, fan, timer,etc) but still no bake or broil. will replacing the relay board AP4008573 fix my problem?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=sve47600w
Here is a manual
http://www.servicematters.com/maytag_library/docs/16010191.pdf
You will notice in the wiring diagram Page 4-29, that there is a hi-limit switch (thermostat) in line with the oven elements perhaps this is open. I believe this is Item 23 in Section 3 of the parts.
I would unplug the unit and check it with a meter.
It took me awhile to get to the switch. went to home depot and spent 10 bucks on a tester. sure enough it’s open. I’ll let you know if replacing it did the trick. thanks, this is my first endeavor in anything like this.
Where is the switch located on our stoves? I’m having a lot of trouble locating it. Thanks
Thanks denman. it works. edee em, the switch is located under the stove top. I had to pull it from the countertop to get to all the screws. You cant get to it from the back. Thanks again denman.
Thanks bf1!
