The bake element in the oven popped and broke. I then ordered the bake element and replaced it. Now everything works except the bake and oven elements. I need to know what part(s) to order. Frigidaire model # FEF366EMD… Thanks
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=FEF366EMD
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316441437.pdf
I would check the wiring from the elements to the control board to be sure it is OK.
If it is then odds are that when the element blew it also blew the control board (Item 20 in Section 1).
Thanks your answers confirmed what I thought. Now how do I test the old control board before I fork over the $85. I’m a Novice so please make it easy for me… Or should I jUst have my homeowners insurance have it repaired. Only problem with that is that they always send out the worst companies to do a job. Plus I can’t take off work for the appointment. Last time I used them it took 2 months and 3 different companies to fix an A/C unit.
If its just a take out screws here then unplug this then screw the new one on then I would much rather do it myself and spend the extra $25. Any advice would be helpful… Thanks
There is really not a good way to check it.
So you check everything else and if it is OK then have to assume it is the control board.
