bake element does not work
this is a 24" GE Range that does not Bake
the Broil element works well, it heats up in both Hi & Low settings.
I replace the Bake element, the Thermal Cut-off switch, and the Bake Relay on the circut board and still the bake element does not heat up.
The Thermostal resistance checks around 11000 ohms, and all the keys on the keypad pass the check test.
what other component could be the cause for the malfunction of the bake element.
Thank you.
