I have a Magic Chef Model CGR3740ADW stove.
When I turn on the "Bake" and set temperature, the igniter comes on (pre-heat LED on), gas comes on, gas ignites but the whole thing (gas and igniter) turn off after about
15 or so seconds!
Originally I had a bad temperature sensor which gave me a F3 error code (and it was open). I replaced that but now have the the above stated issue.
(one thing after another )
The igniter reads about 89-90 Ohms
The Broiler works, igniter comes on, gas comes on, gas ignites and stays on, cycle repeats about every minute or so (maybe longer, didnt time it). It only has two settings HI and LOW, dont know what the temperatures are for each.
Could there be a issue with the Bake igniter (don’t want to swap the Broiler and Bake igniters cause its so difficult to get at them).
Thanks for your help.
Maytag
UPDATE
- BAKE selection is made
- temperature is set (410F)
- Pre-heat LED comes on
- Pre-heat LED goes off in about 5-10 seconds
- Igniter comes on
- gas comes on
- gas lites up
- Igniter and gas shut off in about 15 seconds
- about 2.5-3 minutes the cycle repeats (from step 5)
I hate to think that its the control module
