inop oven
My Maytag (previously called Magic Chef) gas oven with a touch pad will not heat - stays at 100 degrees, regardless of the temp I select. Everything else - burners, lights, upper electric oven works. The gas oven did get hot when I turned on the "clean" cycle but I’m not sure how hot since the oven wasn’t particularly dirty.
Most likely the problem is a bad Bake igniter.
  • The igniter 12400035
    Thanks Gene, Do you know where the igniter is & how to get at it? I can’t find a specs diagram.
    Hi Gene, Do you know where the igniter is and how to get at it? I don’t have a specs diagram. I wish you were in NJ.
It’s pretty simple. Remove the oven floor and the flame spreader. Do not forget to unplug the power cord or turn off the circuit breaker first.
