inop oven
(Correction to Model Number from previous post) My Maytag (previously called Magic Chef) gas oven with a touch pad will not heat - stays at 100 degrees, regardless of the temp I select. Everything else - burners, lights, upper electric oven works. The gas oven did get hot when I turned on the "clean" cycle but I’m not sure how hot since the oven wasn’t particularly dirty.
