Turned on oven, fan came on then smelled an electronic burning smell. Clock works, light works, did a visual on the control board, did not see anything burnt.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=FFEW2725LBB
Here is a wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318416200.pdf
First check the power at the unit.
The elements require the full 240 volts.
Your unit may be hardwired so some of the below may not apply.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK remove power and check the thermostat (thermal cut-off) (item 219 in section 05).
It should be 0 ohms.
