Replaced bake element,but oven won't work
Bake element burned out so I replaced it, but oven (broiler included) doesn’t work. Stove top / control panel all work. Thanks.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=fefb66ece
I am assuming you can program everything but the elements do not come on.
I could not find a wiring for an ECE but looked at ae ECC and an ECF neither had a thermal cutout also I could not find one in the parts.
So that leaves you with a bad control board, burned off wire or a temperature probe.
Unplug the unit and check the wires from the control board to the elements.
Check the oven sensor, should be around 1100 ohms. This is a long shot as usually an error would come up if there was a problem with it.
If the above are OK then odds are your control board is toast.
