Baking Element not working after replacing
I am having trouble with a electric range that had symptoms of that it would not heat up and so in troubleshooting I found that the element was destroyed split in a couple of places. I ordered a replacement based on the model number and installed it exactly as the previous one was.
I am getting the same symptoms now though. How should I troubleshoot at this point, I am thinking the controller should be looked at. I was going to use a multimeter and make sure the power is getting to the appropriate areas but not sure where to go.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=AER5515QAW
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Also check that the unit is staying in preheat.
If it shows that it is ready then it may be a oven sensor problem.
If the above are OK then odds are that when the element failed it also blew the control board.
