amana aer5515qaw bake element problem
hello, over the weekend my bake element on my oven broke, i replaced the element and it still doesnt heat up, i can hear the clicking in the control panel. any ideas would be helpful
i just checked for voltage to the element and there isnt, maybe control unit?
Here are your parts includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=aer5515qaw
Does the broil element work?
If not then it could be a power problem.
Although the wiring diagram is not very legible, it looks like the thermal limiter (Item 18 in Section 1) would kill power to both elements.
You may want to remove the bake element and check it with a meter. Most are around 20 ohms. Not unheard of to get a bad element.
Check the wiring from the control board to the element.
Power Check
If the stove top elements work OK then power is probably OK.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If all the above OK then it is probably the board.
thank you for your relpy, both the bake and broiler do not work, the rest ove the stove works. i checked the wireing and it all seems to look good, but i can not find the thermal limiter switch, any ideas where that might be located?
thank you
Usually on the back of the oven ( Item 18 in Section 1 in the parts link)
i have continuity to the back of the circuit board, not sure about voltage, but i am pretty sure there is voltage to the back of the board, could it b e the temperature probe? if so, would i just check the OHMs?
If it was the sensor then the oven will probably give a false ready.
In other words it thinks it is at set point and therefore does not heat.
The following should be useful to you.
http://www.applianceaid.com/elecrange.html
Check out 7, 8, 20 and 21
