my baking element went out on my stove. changed element. replaced connectors for the element, still nothing,everything else works. so now ordering control panel, when turning it on to bake the broiler heats but baking element stays cold as ice. any other suggestions
It sounds like you are on the right track. Its probably a relay on the microcomputer/oven control.
Just make sure all of your connections fit together snugly. Loose connections generate heat and fail.
