broiler and bake element not working
Was using cooktop burners and broiler element during a thunderstorm- Heard a loud pop (almost like a light bulb blowing but much louder)- The control panel went blank. The circuit breaker tripped. After reseting the circuit breaker, the control panel came on, the cooktop burners also worked, but the broil and bake elements do not work.
Can you help and tell me how to repair this problem.
Thank you.
After resetting the circuit breaker, the clock and all the functions work including the timer. When I select bake or broil on the clock face, I actually hear it click on as it always did. But the broiler element nor the bake element actually ignite. Is it possible you misunderstood my problem? Thanks in advance for your help.
There are three relays on the control board which are providing the power to the Bake and Broil heating elements. One of them is common for both elements (first power leg) and one of two others controls the second power leg to the Bake or Broil element depending on which mode you choose. The click you’ve heard is probably from one of those two relays, but the common relay does not work. In order for the heating element to come "on" there must be both power legs coming to the element.
What is the complete model number of the oven?
black digital
The black control board AP3996731
Broiler & bake elements will no longer heat up - suspect that it’s a display/electronic control problem since for a short time we used to be able to press elsewhere on the display & it would start to work. Now it just doesnt work at all. The display stays on "preheat" & you hear all the clicking sounds it normally makes as if it was actually working, but no heat in the oven - everything else appears to be working fine, no error messages on the display. Kenmore model 665.92152300
Sorry for the delay.
Most likely the problem is a bad control board.
