Banging on spin cycle
On spin cycle the tub bangs like its out of balance. The tub is leaning to the right and rearward while spinning. ( top loading washer) Going from spin cycle to rinse its not as bad. Probably because its not spinning quite as fast. Can anyone help with this problem? Everything else seems to work ok. All settings work, clothes are clean and no leaks.
Whirlpool GLS 9365 EQ1
Thanks in advance for any help
JR
Sounds like a suspension spring problem, or problems with your suspension plate.
Take off the cabinet and start by changing out the suspension springs. It is an inexpensive job and you cannot tell if the springs are bad by just looking.
This site will show you how to get the cabinet off.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin
I have an smooth top electric range from Fridgedaire that is not turning on - intermittently. On Saturday we went to turn on the stove top and it made a zitt (sparking/arching) sound. Then where the clock is it started flashing (if there was an error code we don’t have it anymore). The stove top would not turn on. The oven would work. We unplugged and plugged again and it started working again for a couple of days. Today the clock was off and oven light would not turn on. We pulled out from the wall to unplug and it started working again - even without unplugging. Now it is intermittent. We had the oven working, turned the stove top on - it worked for a couple of minutes - than did not. The element light is still on but the element light would not get hot or turn red. 10 minutes later (we still had the knob turned on) it started heating the water again. Any suggestions?
