Are the bearings available for replacement without replacing the outer tub?
The short quick answer is no, Maytag wants you to replace the tub.
However, some enterprising folks have developed a work around. Check this posting and see if you want to go that route.
http://forum.appliancepartspros.com/washer-repair/57726-neptune-bearing-repair-pic-tutorial.html
