Black streaks on clothes
Hi
Today we pulled out white sheets out of the dryer and they all had black streaks on them. Looks like grease? The dryer has been sounding like it isnt spinning smoothly. Maybe as if there is a problem with the interior felt?
Any help regarding which parts would fix this issue is appreciate
Laurence
Hi Laurence,
Most likely the problem is a bad front felts (upper and lower). It’s also a good time to check the rear bearing. The disassemble instructions are attached.
  • The front felt glide assembly (upper) [part]5303937139[/part]
  • The lower front felt [part]5303283286[/part]
  • The rear bearing assembly [part]5303281153[/part]
Here are the breakdown diagrams and Replacement parts for Frigidaire FDE436RES1 Frg(v1) / Electric Dryer | AppliancePartsPros.com
Thanks for the help!
Is this repair very advanced? I’m very unknowledgable
This job is not too difficult if you know how to handle a simple tools. Read the attached instructions.
great, thanks so much
You are welcome. Keep us posted.
